When you make a slot and insert the dimensions when making it, the dimension is gone when its done.
In the video I start making a slot in a fresh sketch on the newest update.
I set the length of the slot to 40mm and the half circle to 15mm. Only the 15mm dimension is registred.
I know I can go back with the dimension tool and set the length, but its annoying you cant set the dimension while making it as intended by the program.
https://www.youtube.com/watch?v=QvIzVqcqV-U
