Hello everyone I'm new to Fusion 360 and would appreciate some help.
I gather from the tutorial files etc. that the Sketch Palette should include the constraints menu.
As you can see from the screen shot below for some reason they are not present.
I have reset to default layout via the File menu but to no avail.
Version is 2.0.4358
Many thanks, David
Solved by James.Youmatz. Go to Solution.
Hi @Anonymous,
Welcome to the Fusion 360 Community!
You have the new Tabbed Toolbar UI enabled from your preferences which does NOT include the constraints in the sketch palette.
Actually, if you look at the screenshot you posted, there is now a constraint menu under Sketch along the top of Fusion.
Hi James
Thanks for your reply. That did the trick. I found the drop down constraints in the new tabbed toolbar inconvenient to access as I saw no way to leave the drop down open while in sketch mode. I think the palette may be more convenient.
Plenty to learn.
Thanks again, David
