Sketch Origin from Offset plane problem\bug
If you create a sketch on an offset plane the origin will be at the centre of the face the offset plane was created on\from. The problem is if the face is resized the origin doesn't update. Really the origin should either update or be created at the component origin in the first place. The way it works now seems rather dangerous. I would prefer it to update to the centre of the new face, maybe by reselecting the face like the screencast below. The screencast is pretty obvious when I increase from a 50mm wide face to 100mm, not obvious if you increase to 50.50mm though!
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
