Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Sketch Mode inverts / messes up 3D-mouse settings / view model
6 REPLIES 6
ckriesi
550 Views, 6 Replies
I'm using Fusion 360 on Windows 7 and a basic 3D Connexion space mouse. As soon as I click on "create sketch", the mouse gets partially inverted (rotation left/right is inverted) and I can't pan the model anymore. This behaviour does not stop, even if I leave sketching mode. The only thing that fixes it is restarting Fusion, or in other words: Fusion 360 is completely useless with a 3D mouse right now.
Any idea what could be the issue?
Thanks.
6 REPLIES 6
paul.clauss
in reply to: ckriesi
Hi @ckriesi
Thanks for posting! I don't have my Spacemouse on me today, but I will test this out tomorrow and report back.
We often see these issues with outdated 3D Connexion drivers - are you certain you are using the most recent version for your hardware?
Paul Clauss
Product Support Specialist
ckriesi
in reply to: paul.clauss
I checked just after posting - the 3D connexion driver was indeed one version behind. I couldn't try with the updated drivers though, I'll give it a shot tomorrow and see if it fixed it.
thanks,
ck
paul.clauss
Hi @ckriesi
Thanks again for posting! I tested this on my end and experienced no difference with the Spacemouse between sketch and model mode, so this seems likely to be related to the out-of-date drivers. Please let me know if the update helps!
Paul Clauss
ckriesi
Yep I just gave it a quick test with the newest drivers - everything went smooth, which is nice. Let's see if it continues this way. If it occurs again I'll make sure to first update all the drivers.
Thanks!
PS: I'm impressed by the fast support!
alexNAFT9
Hi there. I'm having the same issue on Mac OS. Downloaded latest drivers from 3D Connexion. I am using the original space mouse, with a USB-A wired interface. That device has just fallen off the support list... so maybe that's it.. but I'm hoping someone out there has a solution. The space mouse works great in the normal 3D environment... but as soon as you enter a sketch... it gets inverted, commands change.
g-andresen
in reply to: alexNAFT9
1. Please show the effect in a screencast
2. The latest drivers are not always the best.
For many users, the  driver setting (preferences) "Legacy" is the better choice.
günther
