Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Sketch doesn't show up in simulation tab? I want point load instead of distributed load
2 REPLIES 2
rzhenD6T4M
140 Views, 2 Replies
In Static Stress FEA, I wish to model a point load in instead of a distributed load. The part I am doing my analysis on is a cylindrical shaft. I have created a split body and sketch of the center of the shaft, where I want the force to be. But when I got into the simulation tab, my sketch isn't there. How can I apply a load to this part? I have attached files here. Thank you.
How do I apply force at one point instead of the entire rod?
2 REPLIES 2
Joshua.Aigen
in reply to: rzhenD6T4M
Hi @rzhenD6T4M, I don't use simulation all that often, but I think I found the solution. If you use the target limit the load will focus to the size you specify.
Joshua Aigen
Workshop Supervisor
rzhenD6T4M
That works! But in the future is there a way to define a sketch so I can specify the exact point?
Technology Administrators
