Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
shell issuses
4 REPLIES 4
moseydroop
532 Views, 4 Replies
shell issuses
moseydroop
Hello i am having a serious issues with shelling. every time i go to shell a object, fusion freezes up so that i have to close it and start over, i also have that issue when i go to edit a shell. PLEASE help!....
shell issuses
4 REPLIES 4
jeff_strater
in reply to: moseydroop
jeff_strater
@moseydroop, please share your model here.  Remember that Shell is a very complex operation, and if the model is large and/or complex, it can take a LONG time to compute.  It could be that the operation will succeed if you let it go long enough.  But, if you share the design, we can take a look at it and tell you what to expect.
Jeff Strater
Engineering Director
Jeff Strater
moseydroop
in reply to: jeff_strater
moseydroop
Here is the file. i am trying to shell it to .08 on the flat side.
jeff_strater
jeff_strater
A couple of things I noticed in this model:
first, do you really want to shell the rails/legs of this thing?  One thing you can do is split those off into a separate body, do the shell, then add them back in later.  But, in this case, I think the real problem is the geometry on the domed end.  If you turn on a curvature analysis map, you can see that the middle of that face has extremely high curvature:
This will absolutely cause shell problems.  Areas of high curvature will produce self-intersecting offset faces, which will cause the shell to fail.  Even more important, though, is that there is some bad geometry inside your model.  If you do a section view, you can see that there is a tiny hollow right at the end of that domed face:
You can repair this by going into the Patch workspace, deleting these end faces, and the stray faces, and re-creating the domed face (first creating a sketch point at the dome top), stitching it all back together:
Jeff Strater
Jeff Strater
moseydroop
moseydroop
ok thanks a lot.
ok thanks a lot.
