I can create a Section without issues and it's visible while doing so and when I exit the Section Analysis dialog. If I then turn off the section (eyeball) in the browser and turn it back on it isn't visible. There's outlines changing on the display but I'm guessing there's something to do with visibility settings that's blocking it. Tried various View options and no change. Only way I can turn visibility back on is to edit the section and click OK.
Attached video shows what's going on.
Any ideas?
Solved by P-BvanWyk. Go to Solution.
Solved by iancLTBFX. Go to Solution.
Good day @iancLTBFX,
Have you tried reproducing this on another design?
Seems that your F360 might need a reset.
Thanks Pieter-Ben for the comment.
It appears Murphy is alive and well. Could not get a Section analysis to re-display without editing it first since started using F360 a year or so ago so lodged the post. Continued to have the same issue for several days after with the same project, then suddenly it now works. I just make the analysis viewable in the browser and it appears! No idea what I did to make it work, which is a pity, but "if it ain't broke, don't fix it".
I'm having issues with posts in the Manufacture workspace. Would a Reset make any difference there do you think?
Hi @iancLTBFX,
Glad your section analysis is working, it might have been fixed by an update.
Regarding your post-processor issue, it would be best to make a new post in the F360 Manufacturing Forum.
