I have a part I am working on and once I created the second setup to do the second side it seems to be oriented differently even though everything looks to be correct within the setups. Has anyone else seen this or have any insight into what the issue might be?
Thank you!
Solved by karina.harper. Go to Solution.
Can you post your file? Without it, it's hard to tell what the issue is. Once you post it I can open it up and take a look at it.
Yes that works, or you can post a public link. Here are some instructions:
Hey @ronnieperrin,
Thanks for providing your file!
To restate the question: why is the stock oriented slightly differently in your two setups?
The answer lies in the edges you used as references for the setups. One of your lines is not perpendicular to the other (and not parallel to the other edge you referenced as X for your other setup).
Does that make sense? Let me know if it doesn't and I can make a screencast.
