Scale text
Scale text
denis.spandel
Scale text
denis.spandel
I have the problem that as soon as I have placed and confirmed a text, I cannot scale the text separately using the Sketch Scale
Modify -> Sketch Scale
I know that I have done this before, but I can't explain why it doesn't work now.
Thanks in advance
jhackney1972
If you leave the Text, as you created it, you edit it return to the Text command dialog to change the size.  If you prefer, you can click on the text and Explode it, then you can remove the Fixed constraint and then Scale it.
Edit: Better Animated GIF attached.Explode Text.gif
John Hackney, Retired
denis.spandel
Oh man, you're really fast
Thanks ^^
