A message keeps popping up saying "Unable to insert" when I try to open a saved thing. I dont know what to and this project is due tonight.
Solved by RajkumarIlanchelian. Go to Solution.
@30987D34XF In Fusion can you go into Help - support and diagnostic - get diagnostic log files and attach the zip files here?
Also, if you have the option to switch to another network, can you try that or can you restart your router and then see if it helps?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
