Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Saved Design Disappears
4 REPLIES 4
rodriguezpablo13.pr
210 Views, 4 Replies
Simple:
Designed model - saved project- Exported STEP - closed project because done - come back 2 weeks later - project gone as if never started it - I checked "My recent data" doesn't show up like if it never happened.
I have looked everywhere, thinking maybe it got saved in a different file. Nope - Has never happened. Possible I never saved the project and it's now deleted forever and have to redo it. This did occur during the Windows error worldwide, which could be the culprit
Anyone else have a similar experience ?
Tags (1)
4 REPLIES 4
Check which mode (team or single user) you are in.
günther
Try switching Fusion to offline mode and see if you can find the design. If it shows up, open it then switch back to online and save.
Mark Hughes
Owner, Hughes Tooling
Did not work
Single user only -
