Since the last update or two when I try to export a Body with 'Save as Mesh' I get the dialog box as usual but once I click 'OK' and usually file explorer shows up to select the export directory but this is not happening anymore. Then that tab basically becomes broken. If I click to a different tab then back to the broken one Fusion 360 crashes to desktop. On other applications the file explorer opens like normal so it does not seem to be a Windows issue. This is on Windows 11.
Solved by ChaosBlades. Go to Solution.
I have resolved this issue by Uninstalling Fusion 360 > Rebooting > Reinstalling Fusion 360
