Fusion Support
Reverse lettering in drawing dimensions
5 REPLIES 5
shaiFT4VG
146 Views, 5 Replies
Hello everyone !
After the last software update I have a bug in the dimensions in the drawing
The Numbers of the dimensions is reversed.
The interesting thing is that the PDF comes out fine
It should be noted that I have already contacted the service because it is a serious problem, but I am curious to know if I am the only one.
in the attached picture the cube dimension is 50 mm X 50mm and the dimension is 05
shai
Labels (1)
5 REPLIES 5
-KyleWilliams-
in reply to: shaiFT4VG
The issue is known to us and we are taking a look at this issue, can you please mention the details listed below.
  • what language pack you are using?
  • Are you facing this on Mac or Windows 10 0r 11 ?
There is also this existing thread;
https://forums.autodesk.com/t5/fusion-support/drawing-dimensions-bug/m-p/12902741
Kyle Williams
Senior Customer Advocacy Manager - Design and Documentation
Ontario, Canada
Become an Autodesk Fusion Insider
shaiFT4VG
in reply to: -KyleWilliams-
@-KyleWilliams-  at my work the operting system is windows 11 and  computer the windows is in english with hebrew support and at my home in windows 11 in hebrew same bug
-KyleWilliams-
Thanks for getting back.
Language and regions with right to left text order seem to be affected.
Will update when I can on the progress.
Kyle Williams
Ontario, Canada
Hello @shaiFT4VG ,
This is a known issue and we are working on a fix, as a work around you can change the region and language settings to English and this should get you correct left to right numbers.
Md Adam Ali
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
@mohammed.aliTDPXK  thanks' Mohammed  ,Sachin Krishna form your support team helped me with this suggestion and its working (until the next hotfix)
Technology Administrators
