Repetitive error
Repetitive error
mario.brizida
Repetitive error
mario.brizida
When I have Fusion360 open, I always get this error:
I am the project moderator, I went to Administrator console and didn't see any error or message. 2021 project exists and seems ok.
What can I do to get free of this?
Thank you;
MB
jorge_garcia
Hi @mario.brizida ,
I hope you're doing well. This seems like a more general Fusion issue. I'll see if I can get the correct team to take a look.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Phil.E
Can you please gather your diagnostic logs from the Help > Support and Diagnostics menu in Fusion?
Does this happen on other machines or for other users in this hub?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
mario.brizida
Hi;
In annex I send you diagnostic logs.
By now, only I use this log.
Thank you for your support.
Phil.E
It looks like a design is stuck in the upload queue. Can you try the advice in this article and let me know if that helps?
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fil...
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
mario.brizida
Thank you. Problem solved. I had to manually erase files. Was not enouh to clear cache.
Thanks for your support.
