Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Renaming Parts via Properties Menu
1 REPLY 1
carl.plesslH4XVG
176 Views, 1 Reply
Noticed a bug today while renaming some parts in an assembly - if I right click/Properties on a part, enter something in the 'Name' field, it changes both the part number and the name to the value that I entered, requiring another venture into the Properties menu to renumber the part correctly without it automatically changing any other values.
Anyone else have this happen to them?
1 REPLY 1
Fusion 360 will automatically duplicate the Part Number with the Part Name ONLY if the Part Number has not been changed from the default.  So if you add a specific Part Number to a component then add a Part Name, it will retain both independent values.
John Hackney, Retired
