Relabel Units instead of Convert/Scale Units
I have a drawing that I have imported into Fusion 360 that was made in 2D Autocad. The Units on it are labeled wrong - with all the dimensions being the right values. I simply want to relabel the dimensions to the correct unit - not scale the drawing. ie the drawing shows 100cm and it should be 100ft. If I go to Document Settings>Units and change from centimeters to feet it will change by 100cm to 3.28ft. I do not want that. I want it to be 100ft. Is there a way to simply change the label without it doing all the math of changing the values?
I realize the person who sent me the file should have drawn it in the right units, however, I would like to fix it on my end instead of trying to get them to send me the file in the correct units. The person who sent it is using and old version of Autocad where the units were less important and they are not the most tech savvy.
Thanks in advance
