Dialog box buttons are disabled until camera is moved
MartinMajewski
MartinMajewski
Since the last couple of versions, I am encountering issues with the overlay UI of Fusion 360.
I made a short video showing one issue where the dialog boxes' buttons are disabled as long as the camera is not translated or rotated. Even if all required selections and values are set the buttons, mainly the "OK" button stays disabled.
https://youtu.be/c3PJecZ47ko
The current version that I see this odd behavior is:
Fusion 360 2.0.8560 - macOS 10.15.5
I will report on the other issues in separate posts.
Best wishes,
Martin
bharamk
Dear @MartinMajewski ,
Thanks for sharing your problem and experience with us.
unfortunately I am not able to reproduce the issue in Fusion 360 with version 2.0.8560 on latest update of macOS 10.15.5
You might have already received an upgrade for Fusion360 and the version no is 2.0.8609, Could you please retry and let us know if its still reproducible? if reproducible, Could you please share design document as well.
Thanks & Regards,
Ketan Bharamgunde
Autodesk, Inc.
Thanks & Regards,
Ketan Bharamgunde
Sr.SW Eng.Test
Autodesk, Inc.
MartinMajewski
Hello @bharamk
yes, the issue is not present in version 2.0.8609 anymore, as far as I can tell.
Best wishes,
Martin
bharamk
Thanks for the feedback. Appreciated!
Thanks & Regards,
Ketan Bharamgunde
Autodesk, Inc.
www.autodesk.com
Thanks & Regards,
Ketan Bharamgunde
Sr.SW Eng.Test
Autodesk, Inc.
