My project is arranged where I build individual components in their own file and then insert them into a more complex design and then finally inserting them into a complete large design. So I have a file called "wheel" that's a wheel and another called "axle" that's an axle and then an assembled file of a wheel and axle.
When I make changes to a component the parent component prompts me to sync which i do and see the new components. It seems like the origins are wrong because the child components parts are in the wrong position.
Here is an assembly of a robot wheel, electromagnetic clutch and motor:
And here it is inserted into a larger machine. Note the axle is showing because the wheel is moved away from the clutch. If i want to see the correct image I have to delete it and re-insert it but that's a real problem for more complex parts that take a lot of time to orient correctly. Any thoughts as to what I'm doing wrong?
