Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Reassociate all dimensions after creating a component from the body
7 REPLIES 7
Message 1 of 8
torZ6MPX
510 Views, 7 Replies
I've made a drawing from one body in a design, adding loads of dimensions. Later I created a component from the body and selected the component to be included in the drawing. The dimensions doesn't keep the association to the body which is now in a component, and apparantly all needs to be reassociated manually. Is there a way to reassociate all in one operation?
Labels (1)
7 REPLIES 7
Message 2 of 8
g-andresen
in reply to: torZ6MPX
without insight into the design statements are not possible.
Please share* the file and tell which components, bodies, sketches and dimensions are involved.
günther
* File > export > save as f3d on local device  > attach it to the next post.
Message 3 of 8
torZ6MPX
Can't share the design, so I just made a simple example according to the described procedure. Same result. See first 2 attacments here...
Message 4 of 8
torZ6MPX
... and the remaining attachments here.
Message 5 of 8
g-andresen
just reassociate the dimensions
günther
Message 6 of 8
torZ6MPX
in reply to: g-andresen
Since your reply didn't address my request, I'll repeat the request here, with the main points marked:
Message 7 of 8
g-andresen
NO
günther
Message 8 of 8
roblime
f
