Hi all.
Bit of an odd problem - I can't seem to open or make drawings anymore ! Old ones appear fine as thumbnails in the Data Panel but if you double click on them, it opens the correct Browser but with a plain white Canvas.
Interestingly enough, parts of the drawing do appear if you hover the mouse over where they 'should' be !
Graphics card is a fairly old AMD HD 6870 but that has more than enough grunt to run Fusion and works just fine in the 'Design' window - and it's obviously worked ok before now. As a hobby user, I can't say exactly when this problem started but it was all ok a few months ago.
I've reinstalled Fusion and checked for GPU updates.
Any ideas gratefully received !!
WALLACE
Solved by ClintBrown3D. Go to Solution.
@brownw10
Hello, Wallace and welcome! What is your OS? You said you reinstalled Fusion, so it's probably safe to assume it is the latest version?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
OS is Windows 11 on an unsupported CPU - (AMD FX 9590) but I imagine this isn't the issue - it as all fine when I last made a drawing a few months ago . . .
@ClintBrown3D Any thoughts here?
Chris Benner
Thanks for bouncing this up - I'm still having no luck with it !
I've attached a screenshot recording to show you what I mean !!
This is a graphics issue.
Have a look at this article, it should help you set your Fusion instance up for the best graphics experience: https://clintbrown.co.uk/2023/12/20/fast-graphics-for-fusion-360/
Hello @ClintBrown3D
Thanks for wading in with some help - unfortunately, my shortcut doesn't end in 'Fusion360.exe' but 'FusionLauncher.exe' - and it comes up with 'Target box is not valid' if I try to replace it with 'FusionDocStream\Autodesk\FusionDocAcad\AcCoreConsole.exe'
I've attached a screenshot of the shortcut properties.
Also - why did Microsoft have to break something that was working ? No - on second thoughts, don't answer that . . . .
W.
Hi @brownw10
Set FusionLancher.exe as high perfromance
@brownw10 Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
I can also report the issue. Setting the graphics to High Performance (on FusionLauncher.exe) did not help. Happens on all Direct X 9, 11 or OpenGL. This is quite a recent regression.
Fusion 2.0.20256 x86_64
Windows 11 Pro 22H2 (22621.3737)
I was rather hoping a Fusion update this week might cure it - but no.
It's obviously an ongoing problem - there's an Autodesk support bulletin from August 16th detailing it - unfortunately, without a solution - leastways not that one that would work for me !!
I can't really complain as a 'Personal Use' user - and for the very occasional drawing I need, a screengrab of the sketch with the relevant dimensions does - it's just slightly irritating that something that was working perfectly well isn't now.
Hopefully a few more people will bring this to their attention and we'll get a fix !
Thanks for your help anyway !!
