Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Problem with the command "thicken in surfaces"
2 REPLIES 2
corradofiorentini
104 Views, 2 Replies
Hello everyone.
I apologize for my English.
I drew this surface that comes from a mesh.
At first when I tried to use the "thicken" command it gave me an error.
Then I followed your advice that you had given me in the past: "curvature map analysis" and I found a red area in the lower part of the surface.
I corrected the situation as best I could: the red area disappeared...small points remained (as you can see). I tried again with the "thicken" command.
A strange thing happens to me: if I do +4mm (for example) it works. If I put a number with the "-" sign I get an error.
I attach the file.
Thanks for your help
Tags (1)
2 REPLIES 2
The yellow stitch Icon needs fixing, before the stitch, the surfaces are a lot smaller.
Surface quality will improve with less spline points in the sketches.
Might help...
Technology Administrators
