Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Problem with instalazione di Fusion360 - Problem with installing Fusion 360
15 REPLIES 15
Message 1 of 16
reunionofficina
529 Views, 15 Replies
[Post title translated with Google by CGBenner 5/3/24]
15 REPLIES 15
Message 2 of 16
@reunionofficina Can you please try the below?
1. Close Fusion
2. Go to add/remove program
3. Autodesk Fusion - Modify
This will launch the Fusion service utility
4. Please run the repair Fusion from here. This should help with this issue.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 16
Hi,I make this ...its not working
Message 4 of 16
@reunionofficina This likely will need a reinstall then but please follow the below:
Uninstall Fusion. Then, :
  1. Go to C:\Users\user\AppData\Local\ DELETE folder Autodesk\
  2. Do not use the same Fusion installer. Can you please download the installer again?
  3. Now install again
Autodesk Fusion
Join Fusion Insider
Message 5 of 16
Hi Again
just did it but the result is the same
Message 6 of 16
@reunionofficina Oh wow. I was confident the above should solve the issue.
Ok. One more thing to try:
1. Close Fusion
2. Login to https://login.autodesk360.com/login
3. Go to a design you have and choose "open in desktop"
Does that help to launch the product?
If it does not please do the following to get the logs for us:
1. Close Fusion
2. Add/remove program
This will launch the fusion service utility
4. Run the "Reset Fusion"
5. Now launch Fusion
This will likely fail
6. Go back to the Fusion service utility
7. Run the gather system info
It will generate two zip files
8. Please attach Fusiondiagnosticslogs.zip
Autodesk Fusion
Join Fusion Insider
Message 7 of 16
hi
Message 8 of 16
@reunionofficina @We want the other zip file. Also, did open in desktop not work?
Autodesk Fusion
Join Fusion Insider
Message 9 of 16
ecco
Message 10 of 16
this
Message 11 of 16
@reunionofficina Thanks for the logs. There is some issues with a token refresh for Fusion and still trying to see why.
If it is possible, can you connect your machine to a different network (say your mobile hotspot) and see if Fusion lets you login?
Autodesk Fusion
Join Fusion Insider
Message 12 of 16
Ok today must make this prob
Message 13 of 16
hi Thank you for your time. I just tried connecting the computer to my network from the phone and the program started. But if I switch to the local network will there be a problem
Message 14 of 16
@reunionofficina Thanks for running that test. So something in your home network is blocking the program from authenticating.
Can you restart your home router and then restart your computer as well and see if that helps?
Autodesk Fusion
Join Fusion Insider
Message 15 of 16
Thanks everything is fine and working
Message 16 of 16
@reunionofficina What did you have to do for it to be working?
Autodesk Fusion
Join Fusion Insider
Technology Administrators
