Logged in this morning (4/10/2019 - 7:00:00 AM) to updated fusion 360. Posted a program on UMC-750 and instead of going to its safe home position for B moves, it appeared to go to the machine home position.
Did some investigating and in the post script on line 374 and 375, the position is still called out correctly (X -29. & Y -8.) but it is converting those #'s to metric. So the machine actually goes to X-1.1417 & Y-.315. These seem to be the only problem.
Is anyone else experiencing this issue?
Solved by seth.madore. Go to Solution.
Yes I am experiencing the same problem on our DMG DMU50. Only my Z axis is converting to metric. If I switch my settings in the model to metric, then my Z is correct, but X and Y are wrong. Very frustrating.
Hi guys,
Just wanted to update this thread. We have found the issue and are working on release a fix hopefully by tomorrow morning. Stay tuned.
Using the Okuma post on my Genos 560 having the same issues. Spindle jerking up and down during tool changes and not clearing to top of travel correctly. My old posts went to Z400 and now its outputting 15.748.
Heads-up; An update JUST went live that should address this issue. Test carefully and let us know if it still persists.
Thanks for your patience!
I have logged out and back in several times, and also did shut down, and restart and not seeing any changes in code. I didn't get the green bar that says you are on latest update. Do I need to download something to get the update.
Ron
It "should" go through automatically. However, I'm not quite sure how Mac updates go out, assuming you are on a Mac...
If you click on the "About" button (hidden under the "?" in the top right") what version are you on?
Are you using a modified post processor, or the built in generic post?
You aren't updated, the current version is 2.0.5677. If it hasn't automatically updated by this point, I think your recourse will be to uninstall and reinstall Fusion.
Could you export and share your log files? That would/should give us the tools needed to answer that question
here is the log file, but I already uninstalled and reinstalled. It now is the latest update.
Are these files a "before" or "after" the update?
Was having same issue exactly on Haas UMC 750. Almost crashed machine because of this. It is now fixed as of today, checked with posting out a program. My fix was Find and Replace in the post to switch it back to X-29.0 and Y-9.0
