Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Post Processing with RatRig KillerBee
4 REPLIES 4
richard552CX
290 Views, 4 Replies
Hi all
I've just order a RatRig KillerBee to start learning CAM. I'm an absolute beginner to CAM so please bear in mind.
I've modelled a practice part and setup the tool paths and now I'm ready to post process. However the only machines I can find are industrial level machines like Haas. I also checked the Post Library for Fusion with no luck.
Is there a generic setup that I could amend the XYZ axis parameter to get the post process to work correctly?
The machine I ordered is 1500mm x 1000mm
These are my current inputs
Labels (1)
4 REPLIES 4
j.labdik
in reply to: richard552CX
I could be wrong about this, but I believe most folks with open-source builds use the Grbl post-processor.
I would check this link for more posts that are not built into fusion automatically: https://cam.autodesk.com/hsmposts
You can find the Grbl post and many other posts that might apply to your application. Take a look at the Grbl post though, it's going to be closer than any Haas post will be.
richard552CX
in reply to: j.labdik
I see, I'll have to look into it. It would be a little disappointing if that was the case. (I'll contact RatRig and pose the question)
I did come across this however, potentially RatRig have something similar or this might work been as though there machine is basically a more robust version of the WorkerBee?
https://docs.openbuilds.com/doku.php?id=docs:software:fusion360
richard552CX
Sorry, totally misunderstood you.
The link I sent in the last message was what you was referencing....
Anyway, it looks like I've installed the grbl.cps. Hopefully it works.
Thanks for your help....
richard552CX
Technology Administrators
