When I select or deselect items from the libraries list it seems that my selections should be remembered. Same thing with expanding or collapsing the items in the libraries. None of my selections stick, I have to reselect each time I exit and re-enter the Manage/Tool Libraries. I'm running on a Mac, is this behavior normal?
Thanks much in advance.
Solved by paul.clauss. Go to Solution.
Hi @1Macaddict
Thanks for posting! We have come across some issues with ordering not being maintained in the CAM Tool Library Manager - this has been discussed in this thread.
I am, however, curious about what is not being maintained in your example. Are you referring to the selected libraries to show?
I noticed that Fusion 360 reselected my cloud libraries when I unselected them in the list and closed then reopened the Tool Library Manager. Is this similar to what you are seeing? I did not see any of the expansions in the library list being changed on my end.
Would you mind providing a specific example of a selection that is not sticking so I can see if I can recreate the exact issue you are seeing?
I look forward to hearing from you - please let me know if you have questions.
Thanks much for the quick response.
"I noticed that Fusion 360 reselected my cloud libraries when I unselected them in the list and closed then reopened the Tool Library Manager. Is this similar to what you are seeing? I did not see any of the expansions in the library list being changed on my end."
Yes, each time I open the Tool Library Manager it resets anything I have changed back to all libraries selected and collapsed. For example, if I click the triangle to the left of the Samples library to expand all of the sub categories and leave it that way when I close the CAM Tool Library window, when I reopen the CAM Tool Library everything is back the way it originally was.
Jeff
Hi @1Macaddict
Thanks for posting. I've logged CAM-11165 with the development team to address this behavior and provide a future fix. Unfortunately I was unable to find a way to work around this behavior in the current version of Fusion 360.
We appreciate you bringing this to our attention - please let me know if you have any questions.
