Personal use: "hub configuration failed" when lauching app
mane_sne
Message 1 of 13
mane_sne
Community Visitor
Community Visitor
Tried to login Fusion360 via browser redirect, browser redirects but instead of showing the UI, an error screen is show with error msg, "hub configuration failed".
Replies (12)
Message 2 of 13
richardh3k
Community Visitor
Community Visitor
I have the same problem. Following.
Message 3 of 13
RajkumarIlanchelian
Wre have fixed the issue but working to correct all the impacted accounts. Please direct message me your email ID that was used to register for Fusion.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 4 of 13
piotradamorchowski
BS. Why do you need his email if you rectified the issue? Why do you need his ID? Are you removing bugs manually for every single user? This looks like a pathetic attempt at damage control to me.
Message 5 of 13
RajkumarIlanchelian
@piotradamorchowski @I can explain on why having the email ID will work. For all the accounts that failed we have a queue that it is getting fixed. For anyone that provided an email Id we are fixing it sooner than the queue to get going.
Autodesk Fusion
Join Fusion Insider
Message 6 of 13
fthenry66
I have been wating almost 10 hours for my account to be fixed. this is getting ridiculous.
Message 7 of 13
RajkumarIlanchelian
@fthenry66 Certainly understand and our apologies. We are working to get the accounts that were stuck fixed. Out engineering team is working on this as priority.
Autodesk Fusion
Join Fusion Insider
Message 8 of 13
richardh3k
Community Visitor
Community Visitor
Will we get an email or any notifications once our account are fixed?
Message 9 of 13
RajkumarIlanchelian
@richardh3k @Will reply back to this post once we have addressed the impacted accounts.
Autodesk Fusion
Join Fusion Insider
Message 10 of 13
sarah3deo
Community Visitor
Community Visitor
I sent you a message as it's also impacting me. thanks.
Message 11 of 13
richardh3k
Community Visitor
Community Visitor
Good Afternoon,
The emails that I used are [email protected] and [email protected]
I registered 2nd account since the first one didn't work.
Thank you for your support.
Very Respectfully,
Thong Ho
Message 12 of 13
RajkumarIlanchelian
We have fixed accounts manually for those that have provided an email ID to me. Please login to https://login.autodesk360.com/login to create your hub again and this time it will complete successfully. You can then login to Autodesk Fusion.
We are close to a full solution for those that are still stuck and had not passed on an email ID. Fix for your accounts should be coming very shortly. I will post back here once the full solution is implemented.
We sincerely apologize for this experience.
Autodesk Fusion
Join Fusion Insider
Message 13 of 13
RajkumarIlanchelian
Update on sign-in loop or hub is being configured.
We have now fixed all the accounts that were impacted due to this problem. You should be able to login to Fusion or Fusion team (https://login.autodesk360.com/login) and have access to Fusion.
We sincerely apologies for the inconvenience caused here.
IF any accounts are still facing this issue, please reach out!
Autodesk Fusion
Join Fusion Insider
