Pattern on path bug
Pattern on path bug
johan.rutgeerts
Pattern on path bug
johan.rutgeerts
Pattern on path is not positioning components correctly.
See this thread.
The workaround I present is not really a workaround, as it is too cumbersome, and it breaks if you change the path or want to move your components along the path.
Phil.E
This is a long time issue with pattern on path. It is known and logged already. There is a team working on pattern issues like this. I cannot, for legal reasons, state what the progress is or when a fix will be released. The other post has all the available workarounds from several highly regarded experts.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
johan.rutgeerts
Thank you for your reply.
Which other post do you refer to?
Furthermore: is there some list of known bugs and/or limitations that we can reference?
As it is rather demotivating to go through the trouble of investigating issues, posting detailed problem descriptions, providing example files, then waiting for someone to maybe reply, to finally hear "this bug is a long time issue and well known".
Thank you,
Johan Rutgeerts
TrippyLighting
Yep, I could not agree more!
