Sketcher tangent constraint bug
johan.rutgeerts
johan.rutgeerts
Draw two offset lines, draw a circle tangent to both lines --> works OK:
Try exactly the same, but with projected geometry instead of sketched geometry. --> it fails to compute:
This might be related to this bug.
Example file in attachment.
johan.rutgeerts
I discovered it depends on where you click on the circle:
Click here, it works:
Before:
After:
Click somewhere else, it fails:
EDIT: It's fiddly: if you find a position that works, and then undo and repeat, it often also fails even though you click at a very close position as the one that just worked.
dsouzasujay
Hi @johan.rutgeerts
Thanks for reporting this, I'll pass it on to the development team to investigate
This is clearly a bug. I have created FUS-103945 to track it.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
TrippyLighting
I am 100% convinced the bug is really related to the Offset line. The implementation of the sketch offset has been very shaky from the beginning.
That is the reason I avoid the offset command almost completely!
johan.rutgeerts
I tried again without using sketch offset, see image below.
I get no errors when applying a tangent constraint between the circle and the lowest line.
I get a 'Failed to solve' error when applying the tangent constraint between the circle and the lower projected line.
Strangely it does work with the upper projected line:
