I am trying to open a drawing I have been working with all week. I just need to change some text and send it off and my Friday is done. When I open the drawing nothing is shown. If I select any tool like dimension it hangs with a spinning wheel. I left it for an hour but it still can't resolve. I found a work around for drawings for PC but not for Mac.
Had you been working on it primarily on the PC or MAC? What MAC install are you using, MAS or from Autodesk?
This project is only opened on the Mac. As far as the install goes, I am not sure I understand the question. I installed it from the Autodesk website.
On Mac you can install two different ways, through our website and your account or the Mac Apple Store or MAS.
But that is curious. Does it crash or just stay locked up?
I did it through the website. The drawing does not crash it hangs for at least an hour. I ended up redrawing it but the update also broke my drawing template title block so getting that working out took longer than remaking the drawing. 😕
Sorry to hear about your problems, Colin. Would you be ok sharing your Drawing with us? Feel free to contact me privately...
I'm having a similar issue, though it sounds a bit different.
colinNJB25 seems to have been able to open the drawing but nothing is shown in the view/edit pan.
I can't open my drawing "Swag Pendants - Set of 9 Drawing". There's a spinning icon over the drawing preview, similar to if it was uploading after a save.
See screenshot attached.
I've restarted fusion 360 twice and restarted my computer.
I have a fast active internet connection.
The file showed in the web browser, so I downloaded the file and attached it here.
