I created planes based on points in a sketch using the offset plane to object option. However, when I update the sketch, the planes don't update with the new location of the points. Is there any way to fix this so the planes will update?
please share the file and tell which planes sketches and elements you are talking about.
günther
Take a look at the Screencast. Notice I have no issue executing what you describe. Notice if I did anything you did or did not do. If you cannot replicate the same results, please attach your file and/or a Screencast showing your issue.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Figured it out. I was creating planes on a sketch from another model (skeleton). If I first project the reference points on the sketch, then it updates.
