This is very simple to replicate, but I have not fund any topic about this issue:
1º Create a sketch with a rectangle and define the size for both dimensions.
2º Create a second sketch on the same plane and project the edges of the first rectangle.
3º Create an offset from the projected edges and define an offset size. Ejem:0.5mm
4º Edit the first sketch and modify any of the dimensions.
When I go back to edit the second sketch the projection is updated, but the offset for that projection is not.
There is no option to "Manage lost projections" and it make sense because the projection is fine, the issue is with the offset only.
The only way I have found to fix this is to modify the offset size, once you change it, it will adapt to the updated projected shape again.
Is there any way to update the offset with out modifying its size?
