Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
numbers in drawing sheet flipped
4 REPLIES 4
a.almegbel
134 Views, 4 Replies
Hi.
As in the pictures, any measurement or number typed is immediately flipped (reversed). This only happened after the last update.
21 is written 12
24 is written 42
and so on.
Any help is appreciated.
4 REPLIES 4
Pramod.kadam
in reply to: a.almegbel
Hi @a.almegbel , Apologies to hear that you are facing an issue. We are already aware about this issue and we are working on this to fix on priority.
Just to make sure we are fixing all the cases, can you please provide your machine details like OS, locale etc.
Thanks for reporting this, we will update you as soon as its fixed.
Pramod Kadam
Product Owner
Fusion 360 Drawings
a.almegbel
Hi, @Pramod.kadam .
windows 11,
Version 23H2
OS build : 10.0.22631 Build 22631  (22631.3880)
locale: (English) United States
CPU: AMD-Ryzen-7-2700X
Ram: 48.0 GB
liang_chen
Hi @a.almegbel ,
It seems to be a known issue that happens on Hebrew in OS setting
Showing as attached snapshot, please switch these setting to English and check if it works for you. Thanks
Fred Chen
SQA Engineer
Quality Assurance Team
Autodesk, Inc.
liang_chen
This issue has been fixed in the build 2.0.19941. Please update to the latest and check if the issue is resolved in your side. Thanks
Fred Chen
SQA Engineer
Autodesk, Inc.
