Fusion Support
Not full menu of extrude
5 REPLIES 5
609 Views, 5 Replies
Hi everyone) Why these menus of extrude are different? It's the same command - "extrude" from "control point spline", but if I create CP-spline with more then one control point and extrude it, in this case, I get not a full menu. There aren't these functions - "spacing" and "faces". But if I create CP-spline with only one control point (or FP-spline) then "extrude" has a full menu with those functions - "spacing" and "faces".
 It is noteworthy that before everything worked well and the same, both in the first case and in the second. I have found a video on Youtube that demonstrated it. I attached screenshots.
Thanks a lot for any help/explanation.
Labels (3)
5 REPLIES 5
g-andresen
I have tested it several times and could not reproduce the behaviour.
Does the behaviour occur with every file?
Please share the file.
File > export > save as f3d locally  > attach it to the next post.
günther
in reply to: g-andresen
Hi, Guenther. It happens with any file( Perhaps, I've changed something in the settings of Fusion. I don't know. I attached the f3d file (TEST1) and video.
g-andresen
here´s what I see in your File and a new one I´ve created
günther
Maybe CLEAN UNINSTALL helps
rishabh.bisht
Are your curves degree 3 or degree 5 splines?
We recently enhanced the T-Spline Extrude/Revolve/Sweep commands to perfectly match the degree-3 spline curve.
If a perfect match can happen, Fusion doesn't show the
Spacing and Faces controls on the dialog.
Those controls are expected be used for approximated match, but not for perfect match.
In the perfect match case, the number of faces are determined by the degree-3 CV spline curve.
Rishabh Bisht
Product Owner
From the What's New for June Release:
Rishabh Bisht
Product Owner
