I'm not sure when this started, but my fusion360 sidebar show a bunch of extrusions, right below the sketches tab (see attached photo). I cannot collapse this, and I'm not sure how to get rid of it since there are probably hundreds of these, which makes it difficult to navigate the sidebar. Does anyone know how to remove these?
Solved by g-andresen. Go to Solution.
This form of display shows that you are in direct modeling mode (without history/parametrics).
Delete Extrusions you don´t want
günther
won't deleting extrusions actually delete the extrusion in my workspace? I just want to get rid of the visual clutter, not remove my extrusions...
Rightclick Slidescanner. > switch to Capture History and back to Do not capture History
günther
Thank you! It's too bad there isn't an option that just does this automatically...
you can also select the features in the component browser and choose "dissolve". Deleting the feature will also delete the geometry, and I assume you don't want that.
