Multiple components on a single drawing sheet
Doubletop_
Doubletop_
I am using the personal licence. The personal licence is correct for my hobby use.
I have a design that has a large number of small components I would like to be able to put multiple components on a single drawing sheet. It would be possible to fit say 4 components on a single A4 sheet but I can't see any way of doing this or any logical reason why is shouldn't be possible, even for a personal use licence.
Is it possible?
Pete
g-andresen
create a 2. drawing with this setting:
günther
jhackney1972
I tested the process on a Fusion 360 Personal license and it is possible to place multiple components on a single drawing sheet.  It is however restricted from creating multiple sheets in the same drawing.  Take a look at the Screencast to see the process.
John Hackney, Retired
Doubletop_
That works perfectly thanks.
The problem I had was all my components had been imported and then assembled rather than drawn in the assembly. I was trying to do drawings from the individual components and then drag more components onto the drawing page.
Thats about my lack of detailed understanding to the Fusion360 paradigm. However, what I was trying to do shouldn't be restricted. If users are moving over then they are likely to want to import individual components and possibly draw them. Maybe something to be considered?
Thanks again
Pete
jhackney1972
I sorry you got the impression that you could not use an assembly with Linked Components to place multiple components on one drawing sheet.  I just happened to use an assembly that lacked linked components in my first Screencast, in this one, I used a very small subset of the first assembly that used Linked Components to do the same process.  Again, this was all done using a Fusion 360 Personal license.
I_K_H_
Do you know of any way to accomplish this setup in a template where it would automatically put multiple components on one sheet?
