When I try to say revolve a body with the Free move option it's very difficult now to select the desired handle just by clicking on it. Using the keyboard tab key will cycle through the move options though. Any clues please?
It's driving me nuts.
Start Move,
Set what to Move in Dialogue. (Body)
Select Body.
Click - Set Pivot.
Set Pivot Point and Confirm Pivot is set.
Move.
Might help...
Thanks for reply.
If you see in the picture, clicking on say the revolve handle it's hit and miss whether it highlights to indicate that is selected. It may randomly select one of the other handles such as the XYZ arrows instead. It's only been acting like that very recently. It is behaving buggy on both my pc's.
Thanks again for the reply.
Please create a screencast so we can see the behavior,
I cannot reproduce this on 2 rather different PCs and a 2017 MacBook Pro.
When I first started using Fusion (360) I was told by a very wise man " Don't use "Move" unless your life depends on it...and even then ...DON'T!"
I haven't always heeded his advice but having said that I didn't even know free move revolve was an option....Let me see if I can replicate after current task
Hi.
I've attached an MP4. Hopefully you can open it and see that when I'm trying to highlight a revolve handle or specific XYZ arrow by clicking on it, it invariably stays on it's existing direction indicator. I've only recently had this tool behaving like this and youtube videos appear to show the tool behaving correctly.
Grateful for any help with this.
Cheers
CC
I can see the mouse cursor looking different than usual. Is that due to the screen recording software?
For example, in Fusion, the pointer does not change to a hand, or at least it's not supposed to.
I have the same problem, cursor change to a hand. The move tool when inserting an SVG or a Canvas has the same buggy behavior. The bug appears after the update to the May 2024 version.
I have reported it but they have yet to reply. It might be worth while you reporting it too so they know it's an issue.
Cheers
CC
