Move/Copy Dialog box not showing all options
Ralphie79
Ralphie79
Not sure if this is a bug or a setting i need to check for showing full dialog boxes.
When I select items in a sketch to move and make copy, it only shows the options to the set pivot icon.
From there you need to scroll down to select copy or be able to adjust figures manually.
When I perform the same selection and move / copy it shows the full dialog box.
It's not a major issue, but when doing this a fair bit, it is quite annoying.
gamelife4dns
I also experienced that "too small" Move/Copy dialog window.
It happens also sometimes with the Inspect tool dialog window.
Not blocking, just a bit disturbing.
Steve
HughesTooling
This is an old old old bug that's never been fixed! Only dialogs docked to the edge of the window resize.
If you dock the move dialog to the edge of the window like this it will resize.
Unfortunately another bugs was introduced a few years ago that means this will not be saved between sessions so you'll need to drag the dialog to the edge of the window after every restart.
Mark
Mark Hughes
Owner, Hughes Tooling
Ralphie79
Thanks for the clarification @HughesTooling.
I'll check it out next time.
derekantrican
Is this really still a bug? I'm seeing this too and this is super annoying
