i just had the mirror bug crop up in a design, so made a simple shape and demo to replicate it/ demo it, you can get the file here https://a360.co/2M1LK9L
Solved by karina.harper. Go to Solution.
I've added your report to the existing internal ticket. (FUS-17319)
In cases where mirror fails, using another selection option usually results in a functional model. In this case, if you use 'faces', the mirror works.
Cheers,
Karina
Thanks, Karina.
It was more just having a very simple model to give the Dev's a fighting chance at finding what the issue is, thanks for your reply.
Spencer
