Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Mesh to Brep Missing
45 REPLIES 45
Message 1 of 46
garrett_carroll65
75546 Views, 45 Replies
I can not seem to find where the Mesh to BRep option was moved to. It is not available in the search function, I have the design history turned off and am in the mesh work space.  I am on version 2.0.3802 and using Win 10 Pro.
This is a feature I have used in the past and I did find a video on youtube that was uploaded today show how to do it but they were using mac.
Anyone have an idea as to what is happening here?
45 REPLIES 45
Message 21 of 46
in reply to: garrett_carroll65
I recently had fusion crash multiple times while editing files that where converted from STL to Brep. Now I can not find the option to convert STL to Brep. Design history capturing is off as well.
Message 22 of 46
g-andresen
changed
günther
Message 23 of 46
in reply to: g-andresen
But Why? This just made it more of a pain having to navigate through the menus
Message 24 of 46
Thank you so much!
Message 25 of 46
Hello everyone! I have been studying this problem all morning, but have not yet found a solution ... Last night I did a similar procedure for converting stl to brep, and everything worked! In the morning, when I started the program and opened the same stl file, the operation is lost ... I also noticed that a cover automatically appears on top of the imported model, and the color of the model also changed ... Capture design history is disabled, and there is no mesh menu in the modification menubrep1.jpgbrep2.jpgbrep3.jpg
Message 26 of 46
g-andresen
@Anonymous  schrieb:
.. and there is no mesh menu in the modification menu
Right!
Just have a look at the top registers and select MESH
Günther
Message 27 of 46
hmaxey
I used to use the Mesh to Brep to convert 3d DXF files to a solid body, I've done hundreds of files with it. Now I found the "convert" option, but none of the option will work with the files. I even went back to some of the older ones I converted with Mesh to Brep to try them. Only one option will allow me to select my mesh, and now it fails every time to convert. I need to take the dxf files, keep their shape and make them a solid body for exporting. Anyone have any ideas?
Message 28 of 46
TheCADWhisperer
Expand the Bodies folder in the browser.
What do you observe?
Message 29 of 46
TheCADWhisperer
in reply to: hmaxey
@hmaxey
This seems like a completely different issue.
I was not able to get any geometry from your dxf into Fusion?
Were you, if yes, can you Attach your *.f3d file here.
I opened it in a different software and saved as stp.
I can open the stp.
(See Attached file.)
I recommend that you start a new thread topic on this issue.
Message 30 of 46
hmaxey
in reply to: TheCADWhisperer
You have to upload it and not use the insert DXF function. Inserting as a dxf is going to leave it with no data.  My typical process was like this:
upload 3d dxf
find the bodies I needed in the tree
select all of them and right click> mesh to Brep
click OK all selected bodies would then be solids and not meshes anymore.
then save or export whichever I needed.
Message 31 of 46
Phil.E
in reply to: hmaxey
Thanks for posting this issue. As you may have noticed Fusion now has a parametric mesh workspace. This is not a common workflow (DXF mesh files) and may have been missed in our testing. I've logged a bug for the mesh team developers to look at using your file. Sorry for any inconvenience this causes.
(ref: FUS-87311)
Just closing the loop on this post.
In the July 2021 Fusion update Mesh was introduced as a parametric workspace. Here is a bunch of information about it.
What's New July 2021
Mesh Help page
Mesh modeling workflow videos
Converting Mesh to Solid knowledge article
Inserting Mesh knowledge article
360 Live Deep Dive video
Phil Eichmiller
Software Engineer
Quality Assurance
Message 32 of 46
in reply to: Phil.E
Am new to Fusion 360, Spent four hours trying to convert Mesh to Brep. in personal edition
Watched videos, they seem to work but no dam way can i find mesh to brep menu item.
Have followed this thread and no way can i convert , Mesh to Brep.
So have given up and de-installed this crapware.
Would rather a dog vomited in my ear than ever see this on my desktop again!
Anyone that pays monies for this stuff must be FIVE STAR STUPID.
Get Alibre Design, Oh so easy and MeshCam, Oh so easy.
Final words Autodesk get someone else than Boeing to do your software testing!
Message 33 of 46
I have turned off "Do Not Capture History". I still cannot see the option to turn mesh into a BREP. I cannot find it anywhere.
Message 34 of 46
It is in the Mesh tool tab, under the Modify menu, the command is called "Convert Mesh"
Jeff Strater
Engineering Director
Message 35 of 46
Hi. So. I have this issue as well. I used to use this all the time by RC and turn off design history. Then selecting the mesh, RC convert mesh to Brep. But this is no longer available and I have a PAID YEARLY subscription. So I do NOT have the free version.
So if you have the same as me - I found a way to do it. This may not be the right way but its how I got it to work.
First I saved the project. Then I RC on the very top component and select 'do not capture design history'.
Next I went to the very top (above all the icons) and selected the MESH workspace. Then went to Modify / convert mesh / I selected my mesh and selectred the method / ok. Then up top I went back into the design workspace and RC the top component again and select 'capture design history'. PAINFUL !
Message 36 of 46
Phil.E
Phil Eichmiller
Software Engineer
Quality Assurance
Message 37 of 46
in reply to: Phil.E
Convert Mesh does not show up on my Mesh>Modify menu.  I have the personal license and all that shows up is Convert and there is no selection for Mesh to BREP?  History is turned off and I followed the videos on how to convert the mesh, but nope, doesn't show up.
Message 38 of 46
TheCADWhisperer
No screen capture image shown?
No Fusion *.f3d file Attached?
Old discussion thread.
Message 39 of 46
g-andresen
try this
günther
Message 40 of 46
Thank you for responding, but that screen isn't what I see.  I have attached screenshots and the file I am working with.
