Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Measurement confusions
6 REPLIES 6
370 Views, 6 Replies
I'm a new to Fusion 360.
I have two different circles of different diameter, however using Inspect tool, Fusion 360 showed the same radius and diameter for different circle/curve.
Circle no.1
Circle no.2
Both shows the same diameter and radius although it should be different logically.
The difference between the circle radius and diameter should be 1mm, instead, when inspected independently, it shows the same radius/diameter.
Need help! Thank you very much.
6 REPLIES 6
jhackney1972
When posting a question about a particular model, it is always advisable to attach your model, especially if you want a definite answer about YOUR model.  So please do so and let the forum help you out.
John Hackney, Retired
TheCADWhisperer
... should be different logically.
File>Export and then Attach the *.f3d file that exhibits this behavior.
I wager a box of doughnuts that there is a logical explanation.
in reply to: TheCADWhisperer
My bad. The file is attached herewith.
in reply to: jhackney1972
My bad. Here is the attached f3d file.
TheCADWhisperer
They are both R13 with centers offset by 1mm.
How does that happen? Did I done something wrong?
