Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Measure tool on IPad app not working correctly
1 REPLY 1
sportsmetals
166 Views, 1 Reply
sportsmetals
When using the app, the measure tool will not let you adjust the precision level. It is stuck at .1, which is no help at all. I am running the app on a 4th gen IPad Pro 11”. I noticed several other posts about this with no reply. This makes the app almost useless other than to be able to look at parts. Autodesk should also make an IPad Pro friendly app to be able to draw and edit parts.
1 REPLY 1
jamesmackessy
Yes this is the same on the iPhone, and it really cripples the app for the intended purpose of sharing designs, checking measurements, marking up changes and comments, and collaborating. Hoping that if we all just keep commenting on these threads someone will notice
