I've created a cylinder using two sketched circles of different sized diameters and lofted between them, now I want to measure the angle of the side of the body, how do I do that?
Solved by TheCADWhisperer. Go to Solution.
Why not Revolve instead of Loft?
In geometry what you have described is called a cone rather than a cylinder.
The angle is 93.411672088383° if measured from the horizontal.
You could also measure from the axis.
