I would like to know the maximum file size allowed to upload on Fusion Team.
I've read in a previous post from 2014 (Upload Failed - Maximum File Size? see link here: https://forums.autodesk.com/t5/design-validate-document/upload-failed-maximum-file-size/m-p/5258277#...) the maximum size was 2GB.
As it seems the limitation on upload file size is based on browser I would like to know if this information is still up to date?
Thank you for your help,
Miguel
Solved by brianrepp. Go to Solution.
Hi Miguel - welcome to the forums! Indeed, 2gb is still reaching the limit of what can successfully be handled with Team.
