Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Material I made showing up white when locally rendered
12 REPLIES 12
Message 1 of 13
Brian.Kovesci
1652 Views, 12 Replies
Brian.Kovesci
I've noticed lately that sometimes materials I'll edit will render as flat white when I locally render. In canvas rendering will show the correct material.
I start with a default fabric from the material library and add a new PARAMETERS image and RELIEF PATTERN map just like I would in Keyshot, but it seems like lately local renderings won't recognize adjusted textures. I doubt it's the lighting or the texture itself since the in canvas rendering shows the correct material, it just doesn't produce the quality I need.
12 REPLIES 12
Message 2 of 13
SallyDong2005
Hi @Brian.Kovesci,
Could you let me know what the software you used ? Revit or 3D Max?
Sally Dong
Hi @Brian.Kovesci,
Sally Dong
Message 3 of 13
Brian.Kovesci
Fusion 360
Fusion 360
Message 4 of 13
SallyDong2005
This is a Fusion local rendering problem, I would like to move this topic to Fusion forum for here has more Fusion experts could help.
@Brian.Kovesci it would be helpful if you could share the model to let us check it.
Sally Dong
Sally Dong
Message 5 of 13
Brian.Kovesci
I'll keep fiddling, and if the issue surfaces in a file I'm able to share I'll reply with it.
Message 6 of 13
will
in reply to: Brian.Kovesci
will
Currently having this issue right now too.  in canvas render is fine but as soon as I do local render the material processes as white.  not sure what the issue is.  As you can see the part thats white is not supposed to be white.  it should be showing up like the pillow top on the right hand side.  The pillow top is a linked component and the other white pieces are just bodies
Message 7 of 13
SallyDong2005
in reply to: will
SallyDong2005
Hi @will ,
Could you share a simple file just contain the problematic material to let us check it? It looks like the material is not support well on local rendering.
Sally Dong
Hi @will ,
Sally Dong
Message 8 of 13
phunk80
in reply to: SallyDong2005
phunk80
Hey Guys,
I think this is my first post here, so hello! Is there a solution to this problem? I´ve got exactly the same issue. I modified the downloadable mdf material with another texture (just darkened the .jpg a little) and applied it to a simple assembly. When rendering it appears flat white, while its appearance is correct in the canvas rendering preview.
When I change the material to the "original" MDF, it renders fine.
Hey Guys,
Message 9 of 13
Brian.Kovesci
in reply to: phunk80
Brian.Kovesci
I've found no explanation or workaround. Whenever I see a material render stark white I scrap the texture I created and start fresh or use a standard material.
Message 10 of 13
phunk80
phunk80
Thank you for your help. It ist working meanwhile. I reopened the material and saved it again after applying a change to one parameter.
Message 11 of 13
rafael.samano
rafael.samano
Community Visitor
Community Visitor
It happened to me too. The image I was using as texture was "missing" so I just re-link the image in the advance options of the materials. Hope this helps.
Message 12 of 13
MJHyne
MJHyne
I'm having the exact same issue with a glut of recently created Appearances. I've tried adjusting Brightness, re-attaching the texture image etc, but the issue remains.
In-Canvas & Cloud Render are fine, but Local Render just turns those custom Appearances white. I've not encountered the issue previously with other CA's either.
Message 13 of 13
matt_symbol
matt_symbol
I have the same issue, it's super annoying to put a bunch of renders in the queue and find them with missing textures when I come back!  On a Mac, I tried moving my texture folder from an iCloud synced folder into my Library folder, re-linked the images and so far, it's working fine now.
