Hello all,
With these updates one may fall behind. Work is work and we do not have enough time to keep up on tutorials it seems. So pardon me if this is a stupid question since I was working on a sketch/model just the other day and felt this was a cool feature to try out.
So I have two "sketchs" and have some bodies created off the one sketch. In the sketch the bodies show up in I wanted to draw a line from one body to the other using the 3d sketch checkbox under the sketch palette. I did that, but then I wanted to offset line, to then trim at a meeting point so then it creates a surface to extrude and make a solid from(making a steel beam at at angle between to other beams) . However I cannot offset no matter what I try. Is this a UCS thing or a sketch vs model thing?
Thanks in advance
Solved by jeff_strater. Go to Solution.
offset is a 2D-only operation. It will not work on 3D geometry. It is possible that this will change in the future, but a 3D offset is more complex, so I would not expect it for a while...
