Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
making multiple copies of screws
2 REPLIES 2
cvbsDTXM7
351 Views, 2 Replies
hello,
  I am creating a wooden bench and I need several screws , bolts, washers , nuts etc.  I can find these in the McMaster area and down load, however when I go to make a copy I can only create one.  Once that is copied I can the select those 2 and make copies of them. Is there something I am missing in the copy tool that would allow for specifying number of copies to be made.
Thanks for all the help in advance.
2 REPLIES 2
g-andresen
in reply to: cvbsDTXM7
Depending on the design, you should use the pattern tool.
günther
You can paste how many times you want the same file. You do not need to again copy 2 screw and then paste.
Technology Administrators
