M3 thread projects a 2.529mm hole
rprovideo
Message 1 of 9
rprovideo
Hi
I have two sheet metal components that will be held together by an M3 hole. I created a hol (I think it was d=3 but that should not matter anyway) in the inside component, then added an M3 thread to it. This created a hole thats visibly smaller. its not a modeled thread, but I assumed its so its displaying the thread itself.
Now if I project this circle to the outer component, the projected circle will be 2.529mm in diameter. And it I put this on a drawing, this will end up as 2.5 because of my 0.1mm precision
here you can see the projected hole (overconstrained) and a 3mm hole I drew around it.
its actually visible on the lower compenent too
now I'm new to F360, but I would suppose this is wrong. an M3 screw actually needs a d=3.2 hole. This will result in a component that wont fit together.
Replies (8)
Message 2 of 9
seth.madore
A hole that's defined as an M3 threaded hole will (or should) have a minor diameter of 2.5mm, which is why you are getting that size projected onto your mating parts.
Seth Madore
Message 3 of 9
rprovideo
Correct me if I'm wrong, but should a hole what needs the screw to go thru needs to be the size of the major diameter?
if its created like this now, I wont be able to screw them together.
Message 4 of 9
seth.madore
Did you define it as an M3 tapped hole or an M3 clearance hole. The former will give you the minor diameter, the latter will give you a 3.4mm hole
Seth Madore
Message 5 of 9
seth.madore
Like this:
Seth Madore
Message 6 of 9
rprovideo
I did not use the Hole function, I used the Thread function on an existing hole:
this doesnt ask for anything but should create a standard M3 thread
Message 7 of 9
seth.madore
AFAIL, it's going to reduce (or increase) the hole size to the minor diameter of the thread size specified.
Seth Madore
Message 8 of 9
rprovideo
hence my point - the projected hole should still be the major diameter for the purpose of why you'd project a hole.
Message 9 of 9
g-andresen
It might be helpful if you take a look at the characteristic dimensions of threads.
günther
