M3 thread projects a 2.529mm hole
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi
I have two sheet metal components that will be held together by an M3 hole. I created a hol (I think it was d=3 but that should not matter anyway) in the inside component, then added an M3 thread to it. This created a hole thats visibly smaller. its not a modeled thread, but I assumed its so its displaying the thread itself.
Now if I project this circle to the outer component, the projected circle will be 2.529mm in diameter. And it I put this on a drawing, this will end up as 2.5 because of my 0.1mm precision
here you can see the projected hole (overconstrained) and a 3mm hole I drew around it.
its actually visible on the lower compenent too
now I'm new to F360, but I would suppose this is wrong. an M3 screw actually needs a d=3.2 hole. This will result in a component that wont fit together.
