Lost progress on my assembly, but nothing else seems out of place, need help!
This assembly have lost one year of progress, but all the files i have drawn since then seems to still be there in subfolders as they are supposed to be.
I need help here, is there any way i can recover the latest assembly?
karina.harper
Autodesk Support
Autodesk Support
Hi @Anonymous
Can you describe a bit more what you mean by 'lost progress'? Additionally can you collect your log files and attach them here?
Cheers,
Karina
the assembly file called "SwedishGT40 Ombyggd bakände" have lost every change made since 2020-10-16 (V59)
Then for some reason V60 is from last week (thou i haven't saved any new changes in about an month)
There should be something like 10+ version between V59 and V60, all that has been made on the assembly since V59 isn't there.
The files that are supposed to be referenced into the drawing after V59 seems to be intact though, but not referenced any more.
karina.harper
Autodesk Support
Autodesk Support
@Anonymous
Ok - the logs only contain information from today and the 21st so there may not be much I can decipher.
You said there is a Drawing that is connected to the file that looks correct? Can you try opening the 'uses' tab for the drawing and opening the design from there?
If you can provide some screenshots that would also help.
Cheers!
Karina
I found the answer, but can't for the life of me understand the reason.
The assembly that i have been working on the past year has been moved to another folder, like it was split and the historik version was left and the new version where moved to a new folder.
It is really weird, but oh well, atleast the issue is solved.
