Long file conversion times.
jwilkins8475
jwilkins8475
I think if you're going to force users to do file conversions "in the cloud," you should be obligated to provide the service in a timely fashion.
After three false starts where it said it was working but never went anywhere, I finally got one to actually move and it's going at a rate of ~5% every 10 minutes. This isn't a complex part. It's a ~10x15mm connector insert with some holes through it.
It's particularly infuriating since I know my computer is capable of doing this 10x faster than what I'm getting with The Cloud™, which is your computer and not mine.
TheCADWhisperer
@jwilkins8475
You don't have to do conversion to stl on the cloud.
Can do much much more quickly locally.
Save as Mesh.
Simply right click on the component or body to Save As Mesh...
Not only faster than cloud, but you get more refinement options locally...
This >>same topic<< comes up here several times a day.
